outdoor BBQ gas line
RyanBrant | Posted in Construction Techniques on July 29, 2005 12:22pm
Thinking of building an outdoor built-in BBQ.  The gas line is easy enough to tap into underneath the house.  Running it outside is the question.  My understanding is I need to run green gas pipe, but how do I find below-grade rated fittings?  My local hardware/yard (not HD or Ace, but still for pros) says regular black pipe fittings are fine.  This seems like a rust-through waiting to happen.
And what’s UBC/ICC say, 16″ deep?
Any other hints, suggestions, or pitfalls to avoid appreciated.
  1. marv | Jul 29, 2005 03:48pm | #1
    bump
    You get out of life what you put into it......minus taxes.
    Marv
  2. stonefever | Jul 29, 2005 04:08pm | #2
    As I understand, the code books you reference, will be short on the information you ask due to local soil conditions.
    In S. California, that black pipe would be gone in a year or so from the soil reaction.
    Call your local gas utility, then your local building inspector for what really is required.
    I've had to use a heavy yellow plastic pipe with special ends for my past outdoor grills...
    Don't fool with this issue, pull the permit like you're supposed to.
Choosing a Paintbrush
  • The New Old Colonial
