Outdoor fireplace/oven
pino | Posted in General Discussion on June 28, 2008 05:30am
Anyone know if it is possible to design/build an outdoor fireplace with a wood burning pizza oven above? I’ve seen plenty of kits and design for them side-by-side but we have limited space, hence the one-over-the-other concept.
  1. jeffwoodwork | Jun 28, 2008 05:41am | #1
    Anything is possible, only thing I see is it may get deeper than a side by side.
    1. pino | Jun 28, 2008 06:21am | #2
      Are you thinking one flue for the fireplace and another forward of that for he oven? Any idea where I might look for a set of plans, designs, ideas?I've got a mason wiling to help me out, but he said he'd need a set of plans to work from.
      1. calvin | Jun 28, 2008 01:53pm | #3
        Masonry Heater Association.A Great Place for Information, Comraderie, and a Sucker Punch.
        http://www.quittintime.com/
  2. jjwalters | Jun 28, 2008 02:26pm | #4
    I have an oven almost completed.......built the whole thing out of natural products taken from my property......didn't cost a red cent.
    But in mine the fire chamber IS also the baking area.........
    Start fire ......burn till the inside gets to be about 9oo degrees......either push coals to the rear or wipe out completely.......put in pizza.......put on door........3 or 4 minutes later you have (supposedly) the best pizza in the world........then you bake your bread.......
    I have about a week to go cause I need to work on the opening a bit and allow it to dry...........
    PS...they say the fire below kind aren't quite as good......
    1. Piffin | Jul 01, 2008 02:14am | #10
      "But in mine the fire chamber IS also the baking area....."That is the norm
        Sailfish | Jul 03, 2008 12:59am | #11
        here is some more reading
        http://forums.taunton.com/tp-breaktime/messages?msg=67984.1-----------------------------------------------------------------------------
        "If you come to a fork in the road, take it"
    FatRoman | Jun 28, 2008 04:53pm | #5
    Maybe ask Mike Hennessy.
    He built a pizza oven here (no fireplace to go along with it that I know of, but he might be able to get you going in the right direction.) http://forums.taunton.com/tp-breaktime/messages?msg=100517.3
    Hope that's helpful.
    'Man who say it cannot be done should not interrupt man doing it' ~ Chinese proverb
    1. pino | Jun 28, 2008 05:04pm | #6
      Fantastic thread, thanks for alerting me to it.
        FatRoman | Jun 28, 2008 07:34pm | #7
        Quite welcome. He's done some neat work, and I've tossed that pizza oven idea around several times since seeing his thread.'Man who say it cannot be done should not interrupt man doing it' ~ Chinese proverb
  4. MikeHennessy | Jun 30, 2008 10:35pm | #8
    Pizza ovens are usually "black ovens", i.e., the fire is IN the oven, not underneath it. This is because pizza needs the flame to essentially broil the pizza and extremely high (around 1000 degrees) heat. You can build a decent wood-fired black oven that has a large enough opening that it would serve as an OK fireplace and still cook pizza. You would probably want the hearth at waist height, or more, though.
    FWIW, my wife (My Lovely Assistant) and I built a wood-fired oven last year and love it -- use it almost every weekend.
    Mike Hennessy
    Pittsburgh, PA
    1. pino | Jul 01, 2008 12:27am | #9
      Thanks for the info Mike. I was actually wanting to build an outdoor fireplace with a wood-fired pizza oven above. Same overall structure but one on top of the other. I came across a design that resembled what we wanted, but the problem is that the fireplace would have to be incredibly deep for its flue to run behind that of the pizza oven.Looks like we're going to build the fireplace into the exterior wall of a small rock-face CMU mudroom addition and build the pizza oven separate in another location.
Drafting the 2027 IRC
  • The New Old Colonial
