Outdoor Newel Posts
JoeJoyce | Posted in Construction Techniques on February 15, 2015 07:52am
Hello,
One summer project I have in mind is creating wooden railings on my front stairs – on the north facing side of the house, so only spring and summer sunlight.  I want to create some newel posts at the top and bottom of the stairs.  I want to use wood and hopefully paint them.
My question is what type of wood should I use given that it will be outside and painted?  The stairs will be mahogany.
Any advice is appreciated!
Thanks, Joe, Boston MA
  1. calvin | Feb 15, 2015 09:45pm | #1
    Joe
    hold your horses...
    you you won't be seeing them steps till next October.
  2. JoeJoyce | Feb 16, 2015 10:51am | #2
    True - I hadn't thought of that, even though I had just finished shoveling YET again.....planning ahead I guess.
    Thanks for the laugh.....
  3. JoeJoyce | Feb 16, 2015 10:51am | #3
  4. cussnu2 | Feb 16, 2015 10:54am | #4
    If it is going to be painted anyway, then wood is likely not your best choice.
    1. JoeJoyce | Feb 16, 2015 11:02am | #5
      How about if I wasn't going to paint the wood - what type should I use?
      1. calvin | Feb 16, 2015 11:23am | #6
        Joe
        I've used treated, cedar and fir.  Must say I liked working with the fir best.
        cuts easy, machines well and if you detail the sealing of any cuts, seems to last.
        the cedar I used I found at a fence supply.  They allowed me to sort through which is a plus.  Appreciated me re stacking exactly as I found it and cut me a good price.  Plan (might) on stickering to pull down the moisture content to ambient.  You want it close to your area.  It was a fence company.   They had some real choice posts with minimal knottage.
        The fir was $ more but choice.  The lengths available worked out so only inches scrap.  That from a local quality yard.
        .disclaimer.   Both these purchases about 14 yrs ago.  You mileage may vary.
  5. john7g | Feb 16, 2015 11:44am | #7
    Take a look at what Forrest did http://forums.delphiforums.com/breaktimeclass/messages/?msg=12757.1
    He reused the spinndles but there's no wood in the horizontal pieces IIRC.  Nyloboard.
Fast, Accurate Wall Framing
