Overhead Door Gap Seals
shedhntr | Posted in General Discussion on May 8, 2007 06:01am
I picked up a seal for the bottom of my overhead door recently. The goal is to keep out all of the blowing rain that finds its way under my door. The concrete is less than than perfect under it. Has anyone had any experience with these gap seals, good or bad? Thanks for the help. I might consider returning it if they have limited success.
  1. Stilletto | May 08, 2007 12:32pm | #1
    Use a combination of a new bottom seal and the rubber curb that Overhead Door sells.  The curb glues down to your slab and your door sits on it.
    "If you can dodge a wrench you can dodge a ball."  Patches O'Hoolihan
FHB Podcast Segment: Roofing on Commercial vs. Residential Buildings
In certain scenarios, flat roofs make more sense than pitched roofs (and vice versa).
  • A Postwar Comeback
