Looking to buy the 314 saw for shop use and job-site use. However im unable to find any aftermarket blades. The PC blades probably will do the trick but id like to know if there are other blades out there. I looked and cant find anything but PC blades.
The saw fits my needs however my needs also would like to different blades.
Im posting here and at Knots since this saw might be in the hands of WW as well as trimmers. TIA
WmP,
Tenryu and #### both make high quality blades for the 314. You can find their websites easily by Googling. Don't know what prices will be. Their regular skilsaw blade are around $25.
Probably a good investment for a saw used only for trim....
Edit: Jeez, the program edited out matsush.ita... gimme a break.
Edited 5/5/2003 12:30:39 AM ET by VANDERPOOCH
i've used freud blades 24 tooth i believe . amana carries these blades but never used them. i know tenryu blades have a thinner kerf blades which would optimize the rpm , reduce the drag of the blade. the freud has a heavier kerf which bogs down some what and causes minor splinttering. i just move the saw slower, but next time around i'll think about a thinner kerf blade. the freud does leave a nice cut when slowed down. cut 15 sheets of oak veneer ply for a large entertainment center. and came through like a champ.... slainte....bear
