packing a steel beam
haldi | Posted in Construction Techniques on August 13, 2010 10:11am
I am looking at having to install a steel I beam flush in a ceiling.  joist hangers on both sides. I did this once before and ended up packing both sides with ripped down 2×10. 2 on each side. so I could attach the hangers.
This beam is wider, the flange is 8″, so it would take 3 boards on each side to pack it out, and then thru bolt it.
There’s got to be a better way.
  1. roger g | Aug 13, 2010 10:28pm | #1
    Simple. Weld brackets along the web before you put the beam in place. It's the same way if you wanted to connect steel beams to another steel beam.
    roger
    1. davidmeiland | Aug 14, 2010 11:03am | #2
      Or
      choose a hanger that can be welded to the top of the beam, or hung from packing on top of the beam.
      http://www.strongtie.com/products/categories/top_flange_ww.html
  2. Framer | Aug 15, 2010 03:23pm | #3
    Order it from "Better Header"
    Order it from "Better Header" with it packed out already.
    1. haldi | Aug 15, 2010 05:09pm | #4
      Thanks Joe. Went to the Better Header site. Some great products. Like you said they have I-beams all packed out and ready to go up. The charts didn't show the 10" one that I need, but they say they can do custom sizes. I will need to call them tomorrow and see what they can do,  how much $, if they ship by me, and where to buy.
Two Ways to Test Windows
  • xoxo test post 3
  • xoxo test post 2
  • xoxo test post 1
