Paint gun recommendations?
frenchy | Posted in Tools for Home Building on March 6, 2005 09:09am
I have the usual automotive paint guns,  Binks Devilbuss etc.  however I’m ready to get with the new HVLP guns since I hear they use a lot less paint/varnish to cover the same amount..
  I’ve got to cover approximately 30,000 bd.ft. of hard wood  (Timber frame and I went over board with fancy wood) I expect I’ll use a pressure pot since I’ll probably be using paint/varnish  in 5 gallon  cans.
   Any suggestions as to who makes a good conversion gun?  I have a big compressor with a large 65 gallon tank so air shouldn’t be any problem..
  1. gdavis62 | Mar 06, 2005 10:54pm | #1
    Google for Homestead Finishing, and then contact Jeff Jewitt there.
    He sold us an Accuspray 19c gun, whip, extra needle and tip, cleaning kit, and a 2.5 g. pressure pot on casters.  Super setup.
    You can discuss your needs, and he will recommend the gear.  He sells various professional brands of HVLP guns and gear.  Has a lot of finish lines, also, mainly waterbornes.
    We have sprayed heavy acrylic (Sherwin Williams Pro Classic Waterborne Enamel) on trim and millwork, and oil-based clearcoat on wood trim, both in lineals and in place.
FHB Podcast Segment: Embodied Greenhouse Gas Emissions and the Building Codes
