hey,
am getting different ideas on pressure washing a house as paint prep..as to start from top to bottom or bottom to top….top to bottom seems like obvious choice but have painter friend who swears of reading somewhere of efficiency of workng bottom to top…lizardboy
Anybody who uses a pressure washer on a house ain't no painter.
Why arer you pressure washing? To remove light dirt? To remove mildew? To blast off loose paint?
It will soak the wood, which will delay the painting process. It very well may raise the grain badly, and/or etch away the soft wood.
To answer your question, top down would work well. You don't stain top down because the drip and runs would start to dry leaving uneven coverage.
Whenever you are asked if you can do a job, tell'em "Certainly, I can!" Then get busy and find out how to do it. T. Roosevelt
