Painting an old porcelain sink
Hudson Valley Carpenter | Posted in General Discussion on July 8, 2009 06:49am
Greetings!   There are several expoxy paint products on the market, used for resurfacing old porcelain sinks.
Anyone have experience with this process?  What advice can you offer?
Can you recommend a product?
Thanks, Peter
  1. Danno | Jul 08, 2009 11:11pm | #1
    You may want to look at old discussions with keywords for the search "tub refinishing." This has been discussed quite a bit here.
    1. Hudson Valley Carpenter | Jul 09, 2009 01:29am | #4
      Thanks Danno,
      I tried that and found out what I want to know.
  2. YesMaam27577 | Jul 08, 2009 11:24pm | #2
    It can be done as a DIY thing, but you'll probably not be truly satisfied. Instead of an amazingly smooth finish, there will be some unevenness from brushstrokes, and the color might not be quite what you expected.
    The stuff that can be bought is a two-part epoxy paint. You'll need to do two coats, but there is no effective way to mix just half of the solution. So, you need to be able to do two coats without having the stuff in the can cure up. (Read the label -- usually your home freezer becomes part of the plan.)
    And in general, it will last for only a few years, of light-duty use.
    If you're thinking of doing this so that the house will sell -- DON'T. It will be obvious to buyers, and they'll get a bad impression.
    Politics is the antithesis of problem solving.
  3. VMackey | Jul 08, 2009 11:38pm | #3
    How long do you want it to last? Is it for yourself or a customer? I see warrenty problems down the road. Might work as an artsy project in a little used powder room in your own home. I'd not think about it for a paying customer. I've worked around a handful of good refinishing companies. Not one reputable refinisher will touch a kitchen sink. They get too much abuse compared to a tub. All will refinish tubs and tile as their main business. Some will touch a bath sink and have a very limited warrenty along with pretty much a guarantee that it will eventially chip. Vic
Drafting the 2027 IRC
  • The New Old Colonial
