painting basement concrete
| Posted in General Discussion on July 28, 2005 03:19am
We have just built a new home with a walk in basement. ( The (basement) floor is concrete with the radiant floor heating coils inbedded.)  Until we are able to put down a floor covering we would like to paint the concrete. What is the proper way to do this?  Your help is appreciated.
  1. Homebuilder1 | Jul 28, 2005 09:05am | #1
    What kind of floor covering are you going to eventually put down? If laminate flooring, carpet or hardwood, then ......Is there a vapor barrier under the slab? If not I'd use a sealer (maybe anyway) ... perhaps a urethane or best would be an epoxy formulation made for sealing concrete. (Ventilate and wear a respirator). Seal it before painting it.
    Concrete is very porous to moisture .....
    Good Luck
    Edited 7/28/2005 2:07 am ET by HOMEBUILDER1
Two Ways to Test Windows
  • The New Old Colonial
