Hello all
I did a search on this, but I can’t get a the right sorts of hits – either my terms are too specific (no results) or too loose (a zillion). So, I’m sorry if this has been asked.
Is there a correct was to color match outlets/plates? I grew up in a house where these were just painted over with latex, but that doesn’t seem right.
My problem is, I made raised panel wainscoting from MDF, which was duely painted a light brown. The problem is the color doesn’t go with the standard white or black outlets or wallplates. I can easily make plate from wood, but the outlets I’m kind of stuck with.
I was thinking about spraypainting them with Krylon Fusion or somesuch.
Any suggestions?
I don't know what Fusion is, but there are other colors available besides ivory and brown....
almond comes to mind
, wer ist jetzt der Idiot ?
http://www.smarthome.com/8581b.html
decora wall plate in dark brown - do a search on "decora wall plate brown". Plates are paintable using a good plastic paint (like Fusion); but, you cannot paint the switch/outlet itself. Luckily they come in at least a dozen colours and metalics.
Phill Giles
The Unionville Woodwright
I would not paint the outlet because eventually it will peel. Outlets are never painted in fine work. I try the best to get a color of outlet that goes with the decor, but it's not possible to make it disappear.
check out lutron:
http://www.lutron.com/products/ColorsOfLutron.aspx?pid=Satin&cid=0
Upper left there is colors in different sheens
Oooh.
This looks good. Thanks!
Try this website. You might find something to your taste. I did and as usual it's velly expensive(thank you Mother).
http://www.switchhits.com
One lonely cicada buzzing his song. Apparently, I'm too destructive when I garden.
