painting/glossy front door
user-194923 | Posted in General Discussion on May 7, 2003 02:35am
Hi!
I am not a professional and  a newbie to restoration in general and have a question for painting a front door.  I have used a high gloss paint but want a really, really glossy(and pretty) finish on my front door.  I was wondering if there were a clear finish I could apply that would give this effect? Or would anything else be over-kill???  Or just more work that won’t really make much of a difference?   Thanks for your time, and for not laughing too much at what might be a ridiculous question.
marianne
    ProBozo | May 07, 2003 04:29am | #1
    I would think you'd have to go at it like car painting.  Multiple coats, super-fine sanding between coats, paint sprayed on (and not from an aresol can), then clear coated.
    If it's a steel or fiberglass door, I would seriously think about pulling the hinge pins, take it to a body shop, and let them do it....maybe seven layers of laquer :-)   -- somebody here on the forum paints neat flame jobs, hehehe.  Then take it home and rehang it --- carefully.  Shouldn't be a problem.  You'd just have to figure a way to cover/seal the front door opening for a few days.
    If wood, a body shop would be leary to touch it with automotive paint.  If it is wood, consider buying a new door in steel or fiberglass, leave the wood door in until you get the other door painted.  Doors aren't that expensive.
    Good luck.
    Edited 5/6/2003 9:31:20 PM ET by ProBozo     darn spelling!!!!!
    Edited 5/6/2003 9:34:58 PM ET by ProBozo
  2. PhillGiles | May 07, 2003 05:30am | #2
    Car wax.
    Phill Giles
    The Unionville Woodwright
    Unionville, Ontario
  3. user-194923 | May 10, 2003 12:46am | #3
    Hi,
    Thanks for the replies---the door is wood and the car wax idea intrigued me.  I'll let you guys know.   Thanks for your time.
    marianne
  4. ahneedhelp | May 10, 2003 12:58am | #4
    You don't mention if your entry door is recessed in a porch or directly exposed to sun and weather...
    1. user-194923 | May 10, 2003 06:29pm | #5
      ---the door is recessed and is facing north.  It isn't directly exposed but if a good nor'easter comes along it may get wet.  This is however not the norm.
      marianne
      1. ahneedhelp | May 10, 2003 06:44pm | #6
        re - ---the door is recessed and is facing north.
        Thanks - Wanted to know because we have two sheltered entries that I am planning on refinishing (stain, not paint).
        The door being recessed and protected from weather should give you many more options.
Grout-Free Shower Panels
