Painting inside a fireplace
| Posted in Construction Techniques on June 1, 2004 02:57am
Client had a nice home built 10 yrs ago, with a fully functional brick fireplace, except that she painted the inside black and filled it with dead flowers from the first day.  There are a couple of mortar joints where the paint has failed, and close inspection shows that there is a bit of white powdery stuff under the paint…isn’t that efflorescence?  Anyway, she wants the paint touched up so she can show and sell the house.  How do I need to prep the brick and mortar?  Don’t tell me how to stop the eff-stuff, cuz that means there’s a moisture leak somewhere, and fixin’ that’s not on the table.  there are no signs of a leak anywhere else in the house.
Whenever you are asked if you can do a job, tell’em “Certainly, I can!”  Then get busy and find out how to do it.  T. Roosevelt
  1. WayneL5 | Jun 01, 2004 04:10am | #1
    I would scrub it down with a vinegar and water solution and a stiff brush.  Then rinse thoroughly with water.  After it dries, touch it up with latex (not oil based) paint.
    Normally, a person wouldn't use latex paint inside a firebox, of course, but since she's already wrecked it, you won't be making it any worse and you'll have a satisfied customer.
  2. Piffin | Jun 01, 2004 04:48am | #2
    The efflorescense may not be from a leak but could be from condensation someplace, but most likely a leak. Do the light vinegar and rinse but paint it all. A touch up on something this old will look like a touch up patch job and a whole painting will go faster, unless this is so big it's a wall in chamber.
  3. HeavyDuty | Jun 01, 2004 04:54am | #3
    How about just start a fire, burn off the paint, and the fireplace will look so much better.
    On second thought, I am not sure burning off the paint is a good idea before she moves out. :)
  4. DanH | Jun 01, 2004 06:25am | #4
    Yeah, vinegar, or muratic acid, or whatever other acid you have in the truck.
