Painting Miratec Trim
eskals | Posted in General Discussion on July 7, 2009 05:51am
I just installed some Miratec Trim today. It was my first time using it. Overall I am pretty pleased. I didn’t believe the dust was as bad as everyone says it is. They weren’t lying 🙂
How do you guys fasten this stuff? I used screws because it was a small job that was easier to fasten off a ladder working by myself, and I’m questioning if I would do that again. The Miratec mushrooms up just like the MDF it is. I drilled some very shallow countersinks that helped but added a lot of labor.
Since I countersunk, looks like I will need to patch the screw holes before I put the final coat of paint on. Any product recommendations for patching?
Also, I primed all the cut edges before installing. How do you guys do this efficiently? Just keep a small roller and primer waiting by the saw?
  1. Hackinatit | Jul 07, 2009 07:28am | #1
    Exterior/Interior Oil Base Zinsser Cover Stain. Always have a can or two handy. Spray and wait 15 minutes. Available at Home Depot (NOT AT LOWES).
    http://www.zinsser.com/product_detail.asp?ProductID=12
    A La Carte Government funding... the real democracy.
    xxPaulCPxx | Jul 07, 2009 09:29am | #2
    If you are using screws with Miratec, use the deck screws SPECIFICALLY DESIGNED not to mushroom. They work as advertised.
    Tu stultus es
    Also a CRX fanatic!
    Look, just send me to my drawer.  This whole talking-to-you thing is like double punishment.
Installing Prefinished Cabinet Molding
Use these assembly techniques when installing crown risers and molding to minimize visible gaps and nail holes.
