Painting over epoxy
Northboundtrain | Posted in Construction Techniques on March 22, 2006 06:45am
I’m salvaging/restoring an old pine exterior door for my house.  I’ve scrapped it down to raw wood, and found the surface slightly deteriorated in places.  I believe the door is sound and worth re-using, so I’m planning to coat it with epoxy where needed and repaint it.
My question is whether I can use regular latex primer over the epoxy, or do I need to use an oil-based primer or something else.
    intrepidcat | Mar 22, 2006 09:04pm | #1
    I think white pigmented schellac like B I N primer would be best. You can use a coat of 50-50 boiled linseed oil/ mineral spirits and let that dry for 48 hours before you prime, as a preservative on bare wood.
    Corporate business today measures everything by the size of the silver dollar.
    IMERC | Mar 22, 2006 11:35pm | #2
    what does the mfgr of the 'poxy say...
    WOW!!! What a Ride!
  3. glatt | Mar 22, 2006 11:50pm | #3
    The big thing to watch out for with the epoxy is "blush." After the epoxy cures, most epoxy, especially the less expensive brands, will have a waxy substance called "amine blush" rise to the surface. This must be scrubbed off before anything will stick to the epoxy. A good sanding of the epoxy after it has hardened will probably suffice, but srubbing with warm soapy water and a scrub pad couldn't hurt either.
    Latex and oil paints should both work just fine.
    1. Northboundtrain | Mar 23, 2006 09:14pm | #4
      Thanks,  I was definitely planning to sand it first.  Could I wipe it down with something like denatured alcohol or something instead of washing it with soap and water?
      1. mike4244 | Mar 23, 2006 10:28pm | #5
        Wash it down with naptha.
        mike
      2. csnow | Mar 23, 2006 10:29pm | #6
        You can use acetone or mineral spirits.  Not sure about alcohol.
        1. edward3 | Mar 23, 2006 10:42pm | #8
          Water removes amine blush ( it's water soluble) better than any other solventLet's compromise and do it my way
          1. csnow | Mar 24, 2006 03:35am | #9
            "Water removes amine blush ( it's water soluble) better than any other solvent
            Let's compromise and do it my way"
            Fine and good, but adding water to the material is not always desirable.
          2. edward3 | Mar 24, 2006 11:23pm | #10
            Adding water to which material?
      3. edward3 | Mar 23, 2006 10:40pm | #7
        I use West System Epoxy extenisively in wooden boats. To remove any of the amine blush, water is the best for "blush" removal. Wipe with wet cloth, wipe with paper towels. Remember, this waxy by-product of epoxy can easily be scrubbed off using green ( preferably maroon 7447 ) scotch-brite pads, but change towels often, otherwise, you can end up wiping off the blush, and then wiping back on. As long as the surface is clean, and dulled by scrubbing ( not glossy ) most paints will adhere ( "key-in" ) to the surface.Let's compromise and do it my way
Townhouse Transformation
A sleek, modern redesign maximizes space and light while preserving the building's historical charm.
