painting over existing wall(4×4)tiles—what technique and products will i need to make this a professional looking job? Is this possible? The end product will be a bathroom completely white in color. If there is anyone with thius experience under their belt,please advise me. Removing all the old tiles is my least favorable option.
This centuries-old paint offers vapor-permeabiity, maintainability, and longevity with zero VOCs, but know its limitations before you get to work.
I have heard that melimine paint works but I have not tried it yet Im also interested in painting our tile work I have 2 baths and the kitchen with the same ugly 1970 tile. I cant stand it!!
*I've had wallpaper put over tile in commercial lavatories. The tile is cleaned and the surface is scratched (very slightly) with an aluminum oxide sand paper.A quality primer is painted onto the tile and the paper is adhered to this.Once the primer is on, paint would stick well also.I perfer to use Kilz but there are other primers that are probably just as good.
*Hello Roberto,There are a couple of ways to go about this. Since the tiles are in a bathroom, they will be exposed to excess moisture. This is a problem that must be dealt with in the beginning stages, or you will have problems later on.The painted tiles will occaisonally have to be cleaned, so this is a factor that must also be considered. If there are tiles in the tub area, and they will be exposed to direct contact with water, then method #1 will be your best course of action. If the tiles are on the wall OUTSIDE of the tub area, then method #1 or method #2 will work well.METHOD #1This method requires the use of a two part epoxy paint just like they use to resurface tubs and sinks. DO NOT buy the kit at the local box store for this. This type of resurfacing must be done by a professional who deals in resurfacing tubs, sinks, etc... They have a special application product for tile. It works wonders, but in my area it is about the same price as having the tile replaced by a pro tile installer. Something to think about.METHOD #2This is a very good method, and the results will be long lasting. It is not as good as method #1, but close enough to justify the cost differences.You need to roughen the surface of the tile with sandpaper. I use 150 grit or so, and a hand held orbiting sander for this. You must thoroughly clean the tile and grout before you do anything else. Once the tile and grout are clean, I use a primer made by the WM. Zinsser company called B-I-N. It is a shellac based primer, and works exceptionally well on tile. For more info on Zinsser products, go HERE While you are there, you may want to zip around their site and check out some of their other products.When applying the primer, you will need good ventilation. This primer is shellac based, and has a denatured alcohol base. The fumes can get pretty rough without good ventilation. If you use a brush for application, be careful to catch all the drips. The grout lines are notorious for drips. (I use a sprayer for this)After the primer has dried, I use a premium bathroom grade Acrylic Enamel paint. Brand name isn't as important as making sure that the paint is mildew resistant, and a bathroom grade. There is a difference. I personally spray, but a brush can be used effectively. Just be sure to use a pro quality brush, and again watch for drips. Apply a minimum of two coats, and let the paint CURE for about 7 to 10 days before you attempt to wipe it down. Do NOT aggressively clean the surface for at least 30 days to allow the paint time to fully cure.Good luck...James DuHamel
painting over existing wall(4x4)tiles---what technique and products will i need to make this a professional looking job? Is this possible? The end product will be a bathroom completely white in color. If there is anyone with thius experience under their belt,please advise me. Removing all the old tiles is my least favorable option.
