Painting Parging
| Posted in General Discussion on April 27, 2001 02:30am
The house we moved into last year has a block wall garage that has been covered with parging and then painted white which is now peeling. I’ve had a go at it with a wire brush and it looks like there are 2 layers on top of the parging. What would be best to use to re-paint it with after cleaning up all the loose and flaking stuff?? Should I use a pressure washer instead of the wire brush since there is lots of wall to do??
PS…In the back corner of the garage I found a recipe for ‘white wash’ made from unflaked lime, rock salt, and cement……would this be an option?? Thanks in advance.
  1. Ian.D.Gilham. | Apr 27, 2001 12:22am | #1
    'Whitewash' was the original coating for stucco, bricks, etc. There are far better modern materials to use now, whitewash needed re-doing every year to look good.
    1. Courtney_Ostaff | Apr 27, 2001 04:31am | #2
      *pardon my ignorance, but what's parging?
      1. Ralph_Wicklund | Apr 27, 2001 04:44am | #3
        *Actually:parget n 1: plaster, whitewash, or roughcast for coating a wall 2: plasterwork esp. in raised ornamental figures on wallspargetting vt : to coat with plaster; esp: to apply ornamental plaster to
        1. Jim_P | Apr 27, 2001 02:30pm | #4
          *I've always used the term to refer to a 'skim coat' of cement over top of the exposed part of a foundation. As far as I know it was done for esthetics only in this type of situation.
  2. Jim_P | Apr 27, 2001 02:30pm | #5
    The house we moved into last year has a block wall garage that has been covered with parging and then painted white which is now peeling. I've had a go at it with a wire brush and it looks like there are 2 layers on top of the parging. What would be best to use to re-paint it with after cleaning up all the loose and flaking stuff?? Should I use a pressure washer instead of the wire brush since there is lots of wall to do??
    PS...In the back corner of the garage I found a recipe for 'white wash' made from unflaked lime, rock salt, and cement......would this be an option?? Thanks in advance.
Podcast Episode 691: Replacing Vinyl Siding, Sloping Concrete, and Flat vs. Pitched Roofs
Listeners write in about ground-source heat pumps and weatherstripping and ask questions about engineered siding, concrete that slopes the wrong way, and why houses have pitched roofs.
  • A Postwar Comeback
