Painting Question for Glass
svammen | Posted in General Discussion on January 14, 2005 07:34am
Hello everyone. I am painting a glass vase & I wonder what the best method for a smooth finish is? I primed the glass with a good primer, and now am applying a high gloss acrylic latex paint over. I am using a foam roller, as I worried that a brush would leave streaks. I don’t have a sprayer, which I am believing would create the smoothest finish. What do you think? Brush or roller for the smoothest finish?
  1. UncleDunc | Jan 14, 2005 07:52pm | #1
    What?!?
    1. svammen | Jan 14, 2005 09:23pm | #2
      Hi Uncle Dunc, I'm not sure if something in my post wasn't clear for you? You're reply doesn't really provide much value.
      1. jackplane | Jan 14, 2005 10:37pm | #3
        He understands, he's just in a state of shock.
        An airbrush with compressor would be smooth and provide great accuracy. Then again, I s'pose you could dunk the vase in a vat of latex and let dry, if you take the low-rent approach.
        CapnMac | Jan 14, 2005 10:54pm | #6
        He's probably double-clutching where I am, when you posted that you used a primer on your glass vase, and were wanting to know which roller to use for the finish coat.
        I'm still trying to picture a glass vase big enough to use even a stubby 4" roller on (let alone the "why").  This is not sarcasm, it's more incerdulity, ok?  (If it's not a vase, the answers may be more "on topic" in other words.)
        Now, the technical answer is that you want as smooth a roller (typically) as the finish and the surface.  So, one of the old suede or felt rollers would seem ideal--haven't seen any in dogs' years, though.  As another poster said, I'd be inclined to get out an airbrush, especially for a fine gloss coat.
        Are you using a "glass" paint?Occupational hazard of my occupation not being around (sorry Bubba)
        1. svammen | Jan 14, 2005 11:22pm | #7
          Thanks for the suggestions folks, those are very helpful and I will give it a try. Just for some added clarity (as requested), it is a large, clear glass vase, measuring approx. 3 feet tall with a 1 foot diameter. It is a decorative feature, hence the desire to paint it.
          1. rez | Jan 15, 2005 12:42am | #8
            I'd make a call to a ceramic shop for advice.
            They might have a durable paint they could bake on there for a nominal price..Eenie,weenie...chili-beanie
  2. Matt_S | Jan 14, 2005 10:45pm | #4
    Can't you just BUY a different colored vase?!?!
  3. Matt_S | Jan 14, 2005 10:47pm | #5
    If the vase is clear, then paint the inside. That will leave a smooth finish.
    A brush or roller will not guarantee a smooth finish. The leveling capability of the paint determines how smooth the finish will be.
  4. DonCanDo | Jan 15, 2005 12:54am | #9
    It might be a bit more expensive, but if you don't have access to an airbrush, how about buying cans of spray paint?  It's very easy to achieve a smooth finish.  The only snag I can see is finding the right color.
    -Don
  5. Don | Jan 15, 2005 01:14am | #10
    I am a glass artist - as far as I know, latex won't adhere to glass w/ any reliability. There are special paints used on glass that have to be fired to stick. Doing a vessel as large as the one you are doing is a real chore, and expensive. Google for "pebeo" for a low fired glass paint - about 325 deg F - can be done in your kitchen oven, and is durable. An outfit named Eastman Corp out of CA has a line of glass paints that do not have to be fired - but they are not as durable as I think you want.
    Good luck!
    Don
    The GlassMasterworks - If it scratches, I etch it!
  6. WayneL5 | Jan 15, 2005 01:40am | #11
    Pay no attention to the Philistine responses.  Many of the folks here are construction types who don't understand art.  They mean well.
    1. rez | Jan 15, 2005 01:44am | #12
      Someone slap that boner up the side of the head.<G>Eenie,weenie...chili-beanie
FHB Podcast Segment: Embodied Greenhouse Gas Emissions and the Building Codes
