Painting trim-filling holes
Francorosso | Posted in General Discussion on May 2, 2003 05:11am
Can someone suggest something other than painters putty to fill nail holes in my trim before painting?  I hate the stuff, and here is the reason why:  First, it doesn’t smooth out well when I try to use my fingers to put it in the holes.  It leaves a rough finish or a noticable lump, no matter how hard I try to be smooth.  Second, the stuff requires that you prime it with an oil based primer before painting with latex.  This is a major time waster.
So, please help out with some suggestions on how to make this process of painting a little easier for me (I really hate painting)
Frank Corley
  1. PhillGiles | May 02, 2003 06:05pm | #1
    I've been using wood filler (specifically, LePage Exterior Wood Filler, but I don't think the brand is critical). But this still requires sanding (you were going to do that anyway) and priming (but with a latex primer, you were going to do that too). The guys I was working with lately use Poly Fix Fine Surface Filler for everything (i.e. drywall, trim, holes, gaps, divots, ... - everything). The regular guys on this crew use this stuff year in/year our and can fill a nail-hole using a spatula so well that it wouldn't need sanding.
    If I find that I've missed a hole after I've painted, then I usually use coloured wax to fill it (it comes in wax sticks, that look like crayons, or little jars - you can blend the colours in an old soupspoon with a heat source if you need to do some matching).
    Phill Giles
    The Unionville Woodwright
    Unionville, Ontario
    1. Francorosso | May 02, 2003 08:42pm | #5
      Just to make sure, I was talking about INTERIOR trim work, were you? I noticed I didn't specify when I posted the original message.  Sorry.
      Frank
      1. PhillGiles | May 02, 2003 09:10pm | #6
        Yes, interior, I believe that Poly Fix is mainly an interior product. The LePage Wood Filler is rated as an exterior product; however, that's what seems to make it a good filler under latex paint, it's unaffected by the solvent in the paint..
        Phill Giles
        Unionville, Ontario
  2. vanderpooch | May 02, 2003 06:19pm | #2
    i like durham's rock hard water putty. dries fast and hard, sands easily.
    also had good luck with m and h redi-patch.
  3. vanderpooch | May 02, 2003 06:21pm | #3
    i like durham's rock hard water putty. don't think you'd use it for exterior, but for interior, dries fast, sands well, prime with whatever.
    i've also had good luck with m and h redi-patch.
    1. YesMaam27577 | May 02, 2003 09:55pm | #7
      I like the Durham's too. And I've successfully used it for both interior and exterior applications. For any application in which water or vapor will be a problem, I just mix the stuff with a latex primer, instead of using water. I did this for a window sill repair about 20 years ago, and the stuff is still hanging in there -- looks just like the day I put it in.Vast projects should not be founded on half vast ideas.
  4. KenHill3 | May 02, 2003 06:25pm | #4
    No way that that I know of to get around sanding and priming. I use vinyl spackling or good ol' Synko.
    Ken Hill
  5. RW | May 03, 2003 12:25am | #8
    Crawfords spackle in the green tin. Dries quick, sands easy, paints well. Its my vote for the best gunk in a can I've used.
    "The child is grown / The dream is gone / And I have become / Comfortably numb "      lyrics by Roger Waters
    Qtrmeg | May 03, 2003 12:48am | #9
    I use light spackle. The best brand is Murelo, the second best is Sherwin Williams brand.
Drafting the 2027 IRC
  • The New Old Colonial
