In the near future, I have to do a section of a roof that’s tucked under the rake of another section of roof. I’ve done this more times than I care to think about. It’s an extremely aggravating job because there’s no room to swing the hammer and no room for a nail gun. I’m wondering if anyone has used a palm nailer for this?
When I saw the title I thought you were nuts. But for a small section of roof where access is tight, I think it might work.
Why not make everyone's life a little better and block it closed forever?
Don K.
EJG Homes Renovations - New Construction - Rentals
Yup, it's the answer except for the block it off forver solution.
Joe H
I'd check out the palm nailer you have in mind closely first. I've owned a pair of Sencos, a pair of Cambell Hausfields, and now have a pair of Bostich palm nailers and none of them have an opening large enough to accept a roofing nailer.
That being said, I do recall seeing that some palm nailers come with attachments for various uses. Whether or not one of the attachments would accommodate a roofing nailer, I don't know. But it might be worth a look.
I know all too well of the nooks and crannies of which you speak and they really aren't much fun. As a framer, just trimming out some of these spots creates it's own set of similar problems where you just can't seem to find a way to drive a fastener. So if it helps any.... I feel your pain. ;)
Then you could use a regular nail with a washer instead or a roofing nail.Rebuilding my home in Cypress, CA
Also a CRX fanatic!
I should probably rephrase this. I'm in the market for a palm nailer that accomodates the wide heads of roofing nails. I have spent many miserable hours laying on my belly, on a filthy hot roof, with my head jammed at some weird uncomfortable angle under an eave or rake while struggling to get the last few shingles securely nailed. To use a phrase I overheard my 13-year-old nephew utter once, it is one of the "suckiest" jobs in the world. I tried a right angle drill last time with not-so-hot results. It was hard to get sufficient pressure to keep the bit on the screw head. Does anyone know of a palm nailer or a palm nailer attachment that can be used with roofing nails?
If I can't locate a palm nailer that can be used with a roofing nails, I'll definitely try using smaller headed nails with fender washers. Great idea.
The cheapo Tradesman or Tradesmen kit I have has a square head attachment that might work. I brazed a black impact socket on one of the attachments so I could drive groundrods - works okay.
If you mean non wood shingles...sure. But there is a trick to wood that is easy, nail low and drive it up into the soffit.
BUT, I'd rather make a stop, cuz no matter what you try, a mud wasp or honeybee or a squirrell WILL get in. We recently had just such a problem, and adding screening was the best solution.
I have irriatable Vowel syndrome.
how about a truss or K-lath headed screw and a RT angle driver???
WOW!!! What a Ride!
We use one for this on a weekly basis,we have a 3yr old Senco and ours fits on a 11/4" roofing nail just fine.
I just saw what Diesel posted about the ones he tried not fitting on the head so ya might want to check out different brands for one that works with roofers.
Thanks Woody. I'll definitely look into Senco.
I have 2 Bostitch palm nailers, neither of which would fit a roofing nail with the standard attachment.
One of the Bostitchs came with several attachments for finish nails etc. I'll have a look tomorrow and see if one would work with a roofing nail.
This is a nice kit for the money. Don't know about long term durability. You could call and ask them if there is an accessorie tip that would work with roofing nails.
http://grextools.com/grexusa/products.php5?id=PN1K
http://www.internationaltool.com/woodworking/tools/GRXPN1K.html
Reinvent,
Thanks for the link. I called the support people at Grex and they said the nailer with the kit would work (model # PN 1K). I've ordered it and will report on how well it works when I do the roof. Not only was it the right tool; it was on sale. Many thanks.
