Panelized Framing — Factory Built Walls
| Posted in General Discussion on January 16, 1999 06:33am
Factory built wall framing panels for exterior and interior (studs and sheating only, not stress-skin or foam core)are something that I haven’t seen in my area of central Saskatchewan, Canada, but seems to make sense to me in increased labor and material efficiency and much fewer weather delays. I would be interested in info from fellow builders who have used these panels or anyone with info on manufacturers and specs, pros and cons.
  1. Kevin_Bartsch | Jan 16, 1999 06:33pm | #1
    Factory built wall framing panels for exterior and interior (studs and sheating only, not stress-skin or foam core)are something that I haven't seen in my area of central Saskatchewan, Canada, but seems to make sense to me in increased labor and material efficiency and much fewer weather delays. I would be interested in info from fellow builders who have used these panels or anyone with info on manufacturers and specs, pros and cons.
  2. Guest_ | Jan 16, 1999 06:33pm | #2
    I've been in the truss/wall business for 15 years, so I'll take a stab at it from my point of view.
    I think panels make sense in several situations, but not in all. They can be a labor savings, and can certainly get a building under roof quicker. For instance, the week after new year's, we had tons of snow and ice in central Illinois. Our plant was still cranking out panels and truses while the framers were sitting at home watching Opra.
    The advantages as I see it are: You *can* get dried in quicker (but not always), less scrap to deal with on the jobsite, less jobsite labor required, and lower workman's comp costs. I also believe quality *tends* to be better than jobsite framing.
    The disadvantages are: you have to pick your rough openings out sooner, there can be delays in getting your walls during busy season, and you have to either make sure the foundation is right, or wait until after it's poured and measure it.
    They can either be cheaper or more expensive, depending on how much you're paying for jobsite labor. They really shine in our area on government jobs due to prevailing wage acts. Hopefully, you don't have those in Canada.
    That's all I can think of at the moment. I'd be happy to discuss it further if you have any specific questions.
Old House Air-Sealing Basics
