Paperless drywall vs ‘green board’
20ph | Posted in General Discussion on March 4, 2008 06:10am
I’m rehabing a finished basement that has had mold problems.  This includes a new fiberglass shower which requires new sheetrock around it and on the ceiling.
Not sure what is a better sheetrock product to use:  the old standard ‘green board’ or this newer DensArmor ‘paperless’ sheetrock (Georgia Pacific).
Any comments when one is better than the other?
Thanks,
Jim
    RichBeckman | Mar 04, 2008 06:22am | #1
    I'm doing a bathroom right now. I'm putting in the DensArmor. On a small bath, the extra dollars just are not that much.
    It is true that I don't really know how good or bad the DensArmor is, but I do already know that green board is only a marginal improvement over ordinary drywall, so....
    Rich Beckman
    1. 20ph | Mar 04, 2008 07:11pm | #3
      Thanks Rich.  I though reading that 'green board' is no longer approved for use in bathrooms, etc. but cannot find that information again.  The paperless drywall seems like it is worth a try.
      Jim
      1. homedesign | Mar 04, 2008 07:45pm | #4
        20ph,
        You are reducing the "food-source" with paperless drywall...what about the moisture source?
        Are you taking any steps to reduce moisture?
        John B
        1. 20ph | Mar 05, 2008 08:37pm | #5
          Hello John,
          Yes but my options are limited.
          Thanks,
          Jim
          1. custombuilt | Mar 05, 2008 09:02pm | #6
            Why not just user hardybacker or densheild throughout the whole bath if you are so worried?  And it is not true that greenboard is no longer approved for bathrooms, but rather it is no longer approved be the TCA for use under tile on bathroom walls.
            Either way i think putting up a vapor barrier is going to be the best thing to do.When in doubt, get a bigger hammer!
          2. DanH | Mar 05, 2008 11:40pm | #9
            To be specific, greenboard is no longer approved as a tile backer in wet areas (showers, etc). This is the tile industry's standards group, not code per se, but some codes refer to it.
            Mongo | Mar 06, 2008 07:22pm | #21
            Dan, I'm fairly certain that IRC prohibited it as well with the January 06 revision.Lemme see if i can find a reference...
            Mongo | Mar 06, 2008 07:36pm | #22
            Here's the quickest cut and paste reference that I could find:
            Section R702.4.2 that “Cement, fiber-cement or glass mat
            gypsum backers in compliance with ASTM C1288, C1325
            or C1178 and installed in accordance with manufacturers’
            recommendations shall be used as backers for wall tile in
            tub and shower areas and wall panels in shower areas.”
            There are a few other caveats in there, but it all depends on if the Jan 2006 revision has been adopted by the local agency.
            But as far a good building practices, it's either cement board or fiber cement, which both require a barrier (like 6-mil poly) behind them or Kerdi over them, or a glass-mat product like Denshield, which does not need a barrier behind it but needs proper detailing to cut edges and fastener holes.
            This refers to tile backer in wet areas, like showers or tub surrounds.
            Mongo | Mar 06, 2008 07:45pm | #23
            Wanted to add one more thing:In my area, per code we can't do Kerdi over drywall. But with documentation certificates from Schluter the inspector says we can, but it's on a case-by-case basis.Most guys here know that TCNA isn't code, it's more suited to the "best building practices" category. TCNA is a more flexible agency and it's easier to change than code, so it's usually more timely than code and some local agencies use TCNA guidlines to supplement the national code. It seems to take a cycle or two before TCNA recommendations are incorporated into national code.
    PearceServices | Mar 04, 2008 06:25am | #2
    DensArmor is all I would use. I do not even touch greenboard any longer
  3. sbaillie | Mar 05, 2008 09:10pm | #7
    Durock or other brand cementboard.  Excellent product for kitchens, bathrooms etc.  I would never put drywall in a bathroom, no matter what colour skin it has.
    Simon
    1. DonCanDo | Mar 05, 2008 10:03pm | #8
      Are you referring to the "wet" areas like a shower or do you mean anywhere in the entire bathroom?
      I think greenboard works well in bathrooms, but obviously not as a tile backer.  I haven't used the paperless drywall yet.
      1. sbaillie | Mar 06, 2008 06:31pm | #20
        Entire bathroom.  I am in the middle of redoing the kitchen and I used it everywhere but the ceiling.
        Simon
        1. DonCanDo | Mar 06, 2008 09:18pm | #24
          Wow!  I never heard of anyone doing that before.  I think it's overkill, but it's also pretty good insurance against moisture problems.
          1. sbaillie | Mar 06, 2008 10:44pm | #25
            Not to mention heat.  I believe it can be used to reduce wall clearances for woodstoves in some locals as well.
            Simon
  4. FHB Editor
    JFink | Mar 05, 2008 11:58pm | #10
    USG has actually stopped making what most of us are used to calling "green board", which is called ToughRock MR (the MR stands for Moisture Resistant). They have *supposedly replaced it with another product, which is the exact same shade of green, which is called Mold Tough. (Note: I think they also eliminated Humitek and the other drywall used for wet locations as well...not sure of all the names)
    Mold Tough has a perfect score on the ASTM standard for resisting the growth of mold; I believe both the paper and the core are treated. National Gypsum also has a product that has an equal score, it's purple instead of green.
    I doubt that either are approved for use under tile in bathrooms - they are designed for "incidental moisture" like splashing water, etc.
    * I say "supposedly replaced" because this was transition to the new product happened months and months ago, but my local home depot still has the old stock.
    Justin Fink - FHB Editorial
    1. DonCanDo | Mar 06, 2008 12:32am | #11
      All of these drywall choices can be a little confusing.  Maybe it's time for a FHB article on choosing drywall, something a little more than "what's the difference".
      At the local big box, they stopped carrying DensArmor (paperless drywall) probably because it didn't sell very well.  I have a feeling that the product may have been developed as an over-reaction to the fear of mold.
      1. FHB Editor
        JFink | Mar 06, 2008 12:53am | #12
        You make a good point, and we're on the same page. It's something we might play with in the future.Justin Fink - FHB Editorial
          EricPaulson | Mar 06, 2008 01:02am | #13
          We're getting purple drywall at the lumber yard. I haven't even looked to see who is making it or spec's.
          Mold and moisture resistant we are being told.
          Dens Armor special order only at the Lumber Yard.[email protected]
          1. FHB Editor
            JFink | Mar 06, 2008 01:09am | #14
            That's the National Gypsum XP. I just hung about 100 sheets of it this winter - works just like regular drywall, none of the fiberglass.Justin Fink - FHB Editorial
            EricPaulson | Mar 06, 2008 01:42am | #16
            Large bathroom?
            Ah, basement...........[email protected]
  5. BryanSayer | Mar 06, 2008 01:15am | #15
    Besides the board choice, you have a choice in terms of the taping compound. If you can, stick to the 'hot' muds. They won't react with the moisture in the bathroom once they have set up.
    I used DensShield (I think it was). Watch out for texture, which is good for tiling but bad for painting. In particular, it will be smooth where you tape it.
  6. FNbenthayer | Mar 06, 2008 02:47am | #17
    DensArmor will need to be skim coated and you need to adjust your screw guns to barely dimple the skin.
    We use the "new" 5/8" green board cielings and skim everything that's not tiled.
    The awful thing is that beauty is mysterious as well as terrible. God and the devil are fighting there, and the battlefield is the heart of man.
    - Fyodor Dostoyevski
    1. sledgehammer | Mar 06, 2008 03:17am | #18
      I know you couldn't use the old green board on ceilings... is it the same for these new boards?
      1. FHB Editor
        JFink | Mar 06, 2008 05:10pm | #19
        I think that's changed - though probably still a concern if your spacing is 24 on center.Justin Fink - FHB Editorial
