Parging disintegrating
WillieWonka | Posted in General Discussion on December 11, 2008 06:56am
I have an old house with a stone foundation. The interior was parged many ages ago it seems. Over the last several years it continues to disintegrate into particles the size of sand and in some cases large sections fall out.
Parging is largely done for appearance, correct? And has nothing to do with the integreity of the foundation, correct? I know the parging is disintegrating due to moisture, however there are places where there is no way for there to be moisture and it’s falling apart there also. Also I never see visible signs of moisture on the basement floor (which is concrete) or on the walls, so is this something parging that’s very old does anyways? Do I need to fix this or can I just live with it.
If at first you don’t succeed, try using a hammer next time…everything needs some extra persuasion from time to time.  -ME
Edited 12/11/2008 10:56 am ET by WillieWonka
  1. Henley | Dec 12, 2008 12:28am | #1
    Sometimes people "parge" in the hopes of stopping foundation
    movement (which doesn't work). So check for bulging, leaning, or
    large cracks opening in the joints.
    If none are present then it was probably for looks.
    Moisture can and will cause it to fail. Perhaps the walls are
    damp most of the year?
    Poor quality mortar can also be the culprit.
    Or Portland cement reacting with limestone.
    OR is it in fact plaster?
    1. WillieWonka | Dec 12, 2008 12:36am | #2
      It looks like it's just plain ole mortar. The disintegration and texture of the particles is very much like brick mortar when it disintegrates. I don't see any bulging or movement of the walls.If at first you don't succeed, try using a hammer next time...everything needs some extra persuasion from time to time.  -ME
      1. Henley | Dec 12, 2008 12:48am | #3
        Chances are you don't have anything to worry about. At most it
        is keeping some air movement down.
