Parging mix: need your expertise!
| Posted in General Discussion on August 14, 1999 04:26am
Hey Ross,
The best parging mix depends on the cement you use. If your using portland and a sealbond go four shovels sand, one shovel potland, and half a shovel of sealbond. If your using masonry cement three shovels sand and one shovel cement. I’d go with the portland and sealbond it’s stronger.
Catch ya around,
Tom
  1. Tomothy_Armstrong | Aug 14, 1999 04:26am | #1
    Hey Ross,
    The best parging mix depends on the cement you use. If your using portland and a sealbond go four shovels sand, one shovel potland, and half a shovel of sealbond. If your using masonry cement three shovels sand and one shovel cement. I'd go with the portland and sealbond it's stronger.
    Catch ya around,
    Tom
  2. Guest_ | Aug 14, 1999 04:40am | #2
    Hi fellow construction guys and gals! Does anyone have a good mix ratio for parging a foundation? What proportions for Portland, masonry cement, sealbond, sand? I haven't parged for years, but the last one held up without a crack, I wish I could remember how I did that! Any suggestions? Thanks.
  3. Guest_ | Aug 14, 1999 04:40am | #3
    Ross,
    Just make the mix on the "rich" side (more portland). This will make it "stick" better and not fall off when you put it on.
    Joseph Fusco
Mortar for Old Masonry
