Parging old painted block
TROYLS1 | Posted in Construction Techniques on April 14, 2005 08:22am
I have a 50 year old cinder block (when you drill into it is black/gray) foundation that has a few irregularities, cracks and several coats of paint on it. I would like to parge the whole mess to cover up the worst of it.
My question is do I need to cover everything with wire mesh screwed to the block and then parge or can I get away with powerwashing any loose stuff and applying a bonding agent to the wall, then parging? Any other suggestions? Thanks.
  1. calvin | Apr 15, 2005 05:08am | #1
    troy, I have used Durabond to fill the mortar joints and the first skim on painted block both below and above grade. Never used a bonding agent, tho I don't think it would hurt.  Finished with regular bucket mud.   They have lasted.  Remember of course, moisture from the outside can push off anything you put on block
    Quittin' Time
    Edited 4/14/2005 10:09 pm ET by calvin
  2. Davo304 | Apr 15, 2005 07:00am | #2
    I have used Thorobond bonding agent...paints on with a brush...reddish color. I then go over top with Quickcrete's fiber cement ( also known as B-Bond...is a cement mix fortified with chopped fiberglass). Trowel the B-Bond for a nice finish.
    If unable to find Thorobond...use Acryl 60 for a bonding agent...this stuff goes into the cement mix as an additive rather than being painted on the cinder block . Either should work well.
    If unable to find B-Bond...use Thoroseal...this stuff will adhere just fine...is used for dressing up cinder block all the time...only problem I've noticed is that if applied too thick, it will eventaually crack. B-bond could also crack, but I seem to have better luck with it.
    Davo
  3. ponytl | Apr 15, 2005 07:04am | #3
    i think you can power wash it... with a real power washer ...something like..3500 psi belt drive unit min with a turbo nozzle... 10-15 hp
    point up/skim over... the bad places with a rich portland/sand mix  after apply'n it i use a scrap of  white styrofoam to rub it down circular motion blends it in well... do this on a damp wall...  keep same damp fo a min of a 3-4 hours...  2-3 days is better... damp not wet... then i mix a mix of 1 part portland 1 park fine clean white sand... i use white portland with a touch of gray portlant to knock out the "white whiteness" i mix this pretty wet and i scrub it into the wall... i use acid wash brushes that are made for acid clean'n new brick...  this stuff will set up quick... again... apply it to a damp surface and keep it damp...  it cleans up ur old surface well and should last for years
    pony
    1. TROYLS1 | Apr 15, 2005 01:55pm | #4
      Thanks for all the info guys, you have saved me a ton of work as I was leaning towards overkill and adding the mesh. One more thing, around the basement windows is older 2x PT wood that has shed most of its paint, could I clean this up and parge over this as well or would this require mesh? I am pretty sure it will require mesh, but I can hope!
      1. UncleDunc | Apr 15, 2005 02:03pm | #5
        Just personal opinion, but I wouldn't parge over wood, even pressure treated.
