Paslode fuel
ponytl | Posted in Tools for Home Building on March 8, 2006 04:41am
I posted  a while back about leaking fuel cells… the ones i had that leaked when you popped the valve in all had a MAY07 date code…  today i had one with a june07 date code that leaked when i popped/pressed in the valve…  after twisting and getting it seated it stopped… but if i hadn’t checked it for leaking it’d have emptied itself… anyone else listen for leaks when use a new fuel cell?  I never did till i ran into a batch that sounded like a tire going flat as soon as you pushed the valve onto the cell….
p
  1. Shep | Mar 08, 2006 05:03am | #1
    Haven't noticed that with the cells I've used, although some recently seemed to not be lasting as long.
    I'll try to pay attention, thanks for the heads up.
