Patching a Small Hole in Plaster
corrib | Posted in General Discussion on April 8, 2007 06:18am
Any suggestions on how to patch a dime sized hole in 1920’s plaster?
I filled the hole with compound and tried to feather out the patch. The compound only filled the hole and didn’t blend at all. It looks like a white spot in the middle of my green wall, with the edges of the hole smooth but well defined.
What am I missing here? Do I need a bigger trowel than 6″? Should I clean out the hole and start over with some tape?
Anyway, if anyone’s got any suggestions I would appreicate it! It certainly doesn’t have to be perfect, but….
Thanks!
Patrick
  1. PhillGiles | Apr 08, 2007 07:58am | #1
    if you're asking what I think you're asking; you need to tint the new plaster the same colour as the plaster.  If you're going to paint over it, you just need to seal it with B.I.N. or shellac to stop it from telegraphing through the finish coat.
    PS. I 've had mixed luck trying to tint the lighter plaster (i.e. patch has been made) with ivory artist's wax or artist's felt pens.
    Phill Giles
    The Unionville Woodwright
    Edited 4/8/2007 1:01 am ET by PhillGiles
  2. woodroe | Apr 08, 2007 07:59am | #2
    Have you tried painting the patch green like the rest of the wall?
    P.S. sand the patch with a sanding sponge, you're sanding off too much of the compound.
  3. dovetail97128 | Apr 08, 2007 08:20am | #3
    Sounds as if the patch is bonding to itself but not to the surrounding plaster.
    Plaster is best patched with plaster, clean the patch area well , blow out any dust , dampen the edges of the patch area and p[atch with plaster.
    Seal with Kilz or equal then paint.
    1. Danno | Apr 08, 2007 10:36am | #4
      Was going to say the same thing--dampen the are to be pastched to new gits incorparated into old.
