do I need a footing under a 4 inch concrete patio slab, nothing will ever br on it but BBQ grill, the dog, and family
Prescriptive codes don't address the connection at less common angles, so base the connection off more typical ones using bolts, structural screws, blocking, and steel tension ties.
No. It would serve no purpose unless the slab will be later converted to an addition.
