patio doors with a shed roof?
BVJohnston | Posted in General Discussion on August 28, 2008 09:34am
I am in the process of residing my home and was getting to the back of the house which has a patio door.  I live in a bungalow and was going to replicate the shed roof on the back door over the patio door.  I may make it a little shorter and wider than than the door shed roof.  I was just wondering if anyone has any ideas or opinions on this? Is it worth the trouble or should I just leave the patio door as is?  I thought it may add little character as well.  Any input?
    ToolFreakBlue | Aug 28, 2008 10:40pm | #1
    I think adding an overhang would be a good thing.
    For what it's worth, this is on the warranty page of my door supplier:
    “Misuse” of a door includes, but is not limited to, using
    a door on part of a building without providing adequate
    overhang or an appropriate finish color. Adequate
    overhang depends on the typical weather conditions
    of the area where the door is to be used, but typically
    means an overhang projecting a distance from the
    structure one half the elevation difference between
    the bottom of the door and the base of the overhang
    structure at the point which is farthest from the door.
    In order to reduce the chance of warping or checking,
    dark colored finishes should be avoided on all surfaces,
    especially on light colored wood species, or if the door
    is exposed to direct sunlight.
    TFB (Bill)
      BVJohnston | Aug 29, 2008 05:38am | #2
      Thanks TFB!
      I was thinking it would not only give some symmetry to the back of the house but as well keep some of the elements out. It would be a simple shed roof but I thought about some nice stained bead board on the inside to keep it bright. Gives some protection from rain and the sun, since the back of the house faces east and it gets pretty warm. Have a good one!
        ToolFreakBlue | Aug 29, 2008 06:10am | #3
        Sounds cool. Take pictures and share it with us.TFB (Bill)
Two Ways to Test Windows
  • The New Old Colonial
