I have an in-ground fiberglass pool with the fiberglass coping exposed and want to but a tile or paver up to the coping to extend the coping and add aesthetics. The deck is concrete and the fiberglass coping is about 1-1/2″ higher then the concrete deck. The climate is the extremes of Michigan. Any suggestions -Thanks!
FHB Podcast team chats about adding Larsen trusses to an existing stud-frame home with no additional sheathing.
go to lawnsite.com and find the hardscape column, lot of good stuff there by some top notch pros.
Thank you, just joined their forum.
