Just got a new Tool Crib catalog. They have the PC 5″ Orbital and Makita 5″ Orbital at $59.99. I’m gonna buy one or the other…anyone used both? Positives & Negatives?
I haven't used both but I have a few PC's one is about 6 years old, only had to replace the hook and loop pad because it wore out, still going strong
I've used both but prefer the PC 333. My 333 is an older model (1.7 amps) and has seen plenty of use. No problems .......... I blow it out every once in awhile and have replaced the o rings on the dust collection canister a couple of times. I think the PC is a smoother sander. The only possible negative is that the 5 hole paper that PC uses isn't as widely available as the 8 hole paper that the 8 hole paper that Makita uses but I've never found it to be a problem. Check out Klingspor for paper ........... good paper and prices. http://www.woodworkingshop.com/
sounds like a good value at <$60. HD also has the 333 at $59.
