PC hinge mortise template accessories
gdcarpenter | Posted in Construction Techniques on September 30, 2007 06:42am
Been using the Porter Cable hinge mortising kit. Trouble now is running into having to mortise for hinges with large (5/8″) radius, and the standard template frame just won’t do that.
Apparently there are ‘accessory’ templates for larger radius hinges but me ‘surfing’ skills, or lack thereof, have not found same. Anyone have an idea where to locate such beasts?
Let’s not confuse the issue with facts!
    ToolFreakBlue | Sep 30, 2007 07:29am | #1
    read thru the reviews on Amazon. You will use a 1 1/4 dia bit and a certain collar, not sure which one.
    TFB (Bill)
      gdcarpenter | Sep 30, 2007 07:54am | #2
      Thanks Tool Freak Blue. I figured that would work if I can find a collet that size. Just seem to remember in the instruction manual that there were PC part numbers for the accessory templates. Will look Monday.Let's not confuse the issue with facts!
      1. Howard_Burt | Sep 30, 2007 09:43am | #3
        gdcarpenter,
        The PC accessory number your looking for  is: 42048 router template guide specifically for 5/8" radius hinges.
          gdcarpenter | Sep 30, 2007 08:20pm | #4
          ThanxLet's not confuse the issue with facts!
  2. reinvent | Oct 01, 2007 12:38am | #5
    Man those kind of hinges are UGLY!
Picture-Perfect Pergola
