The paint is peeling off my plaster ceilings (also pulling off a thin layer of the plaster). I’ve already tried sanding, sealing with Bin and recoating, but this failed within months. Any suggestions?
Amy
Amy
Check out the lineup for the 2024 Building Science Symposium featuring experts like Steve Baczek, Dr. Joe Lstiburek, and more.
Amy,
Where is the peeling occurring, 1st floor, 2nd floor? Towards the edge of the ceiling or is it more uniform? All rooms or just some? By "recoating", are you patching any of the areas where the paint has pulled plaster off with either new plaster or joint compound, or are you just repainting after sealing?
I'm asking because I have the same problem in only one room, except it's the walls (all four of them, pretty much uniform peeling) instead of the ceiling. Does the attached picture resemble the type of peeling you're experiencing?
-Andy
*It might be an old layer(s) of calcimine paint that is the problem. http://www.uwex.edu/ces/flp/house/floor/flr_011.htmlHope this helps.
*http://www.uwex.edu/ces/flp/house/f_index.htmlThat site looks like worth bookmarking!
The paint is peeling off my plaster ceilings (also pulling off a thin layer of the plaster). I've already tried sanding, sealing with Bin and recoating, but this failed within months. Any suggestions?
Amy
