perfect perpendicular holes
DIYjimmy | Posted in Construction Techniques on October 4, 2021 09:03pm
Forum – we’re opening up our basement and removing one of the lally columns supporting one of the 6×8 beams. To strengthen the beam for the 10’ span the engineer specified to flitch the wooden beam with c-channel. The flitch is on either side of the 6” beam’s width.  It’ll be welded to a plate and the lallys at either end. So far so good. But the design also calls for thru bolts every 12” on a zigzag pattern across the span, so 10 bolts. My question is, what is the best way to drill these holes? For the straightest holes should we drill from one side to the other, or from each side to meet in the middle? Should we transfer the hole pattern to either side of the wood beam or get the steel in place and drill the holes using the pre-drilled steel as a guide? What are the tricks to ensure that the holes are perfectly perpendicular and aligned? thanks!!
  1. mikemahan3 | Oct 04, 2021 09:18pm | #1
    Ask the engineer if lags are acceptable. If so predrill each channel and bolt from both sides.
    1. DIYjimmy | Oct 05, 2021 07:45am | #2
      great idea. will ask and let you know what he says. anyone else?
  2. florida | Oct 05, 2021 10:13am | #3
    Drill from both sides. It's pretty easy if you're careful.
  3. bing0328 | Oct 05, 2021 11:01am | #4
    Remember also that the hole you drill should be 1/16" wider than bolt. That alone should give you some wiggle room.
  • xoxo test post 3
  • xoxo test post 2
  • xoxo test post 1
