PERFORMANCE SHOWER
mavrick | Posted in General Discussion on November 3, 2006 08:39am
My question is no the merits of a recirc system, but can it deliver sufficient hot water to a high performance shower system needing 15+ gpm.  What size/spec hot water heater is recomended?  Any sugesstions would help.
  1. Scooter1 | Nov 03, 2006 07:10pm | #1
    I don't know about recir systems, but a tankless water heater will keep up with that flow rate all day long.
    Regards,
    Scooter
    "I may be drunk, but you're crazy, and I'll be sober tomorrow." WC Fields, "Its a Gift" 1934
    1. Tim | Nov 03, 2006 07:30pm | #2
      Which tankless water heater(s) will provide hot water at 15 gpm?
      1. Scooter1 | Nov 03, 2006 07:35pm | #3
        Noritz has several models. They can also be daisy chained to increase capacity, so their capacity is unlimited.Regards, Scooter"I may be drunk, but you're crazy, and I'll be sober tomorrow." WC Fields, "Its a Gift" 1934
  2. MikeHennessy | Nov 03, 2006 10:38pm | #4
    The existence of a recirculating system should have no effect on this except to save the fraction of a second it would take the hot water to get from the tank to the shower. (At 15 GPM, you wouldn't have much of a wait!) That said, even a 50-gal tank would be empty after about 5 minutes or less and I am wondering what is planned to make sure you can drain this deluge away? Sounds like a fire hose more than a shower. A 15 GPM shower kind of makes the water-saving toilet seem a bit, er, pointless?
    Mike Hennessy
    Pittsburgh, PA
    1. mavrick | Nov 03, 2006 11:33pm | #5
      Aggreed.  I'm not concerned with water savings in this case and I'm no sure a recirc system is the way to go.  I'm more concerned with delivering an adequate supply of hot water to the shower.  Could one 75 gal. do the trick or 100 gal. or do I need tankless?
      1. Scooter1 | Nov 04, 2006 12:13am | #6
        Do the math. How long is your longest shower? Will anyone else be doing anything else for the next hour, like clothes, dishes, washing their hands?I think only tankless or 2 80's would do the trick.Regards, Scooter"I may be drunk, but you're crazy, and I'll be sober tomorrow." WC Fields, "Its a Gift" 1934
  3. Grott | Nov 04, 2006 02:08am | #7
    With that much volume I would look into tankless. Also a waste water heat recovery system to temper the supply to the H2O heater. I think the term is GFX, for Gravity Flow heat eXchanger.
    Garet
