Pergola on deck questions
Mulch | Posted in Construction Techniques on May 1, 2007 10:52am
I’ve got a couple issues I’m wrestling with and hoping for some inspired input here.
I’m going to be installing a pergola over one end of an existing deck which stands 10′ off the ground.
The deck is framed with PT, 6×6 posts, 2×10 joists on 16″ centers, ledger attached to rim joist, decked with 5/4 x 6 Ipe decking.  Entire deck is 15′ deep from house, about 26′ wide.
House is a Ryan home with vinyl siding.
The plan is for an Ipe pergola approx 13′ square (with 2’overhang) at one end of deck.
I’m hoping to use 4×6 Ipe posts, let through the decking and resting on top of the 6×6 posts for three corners.  2×8 beams for pergola will run perpendicular to house, with 2×6 joists on 16″ centers running parallel to house.
Problem is 4th post next to house near center of deck.  I don’t want to have to dig another footer right next to house under deck and then use an 18′ post (if I can even find one in Ipe).
Can I add extra joists/other framing support running from deck ledger to beam underneath to support fourth post.  Should I try and tie the end of the pergola beams to the wall framing somehow (2×4 on 16″ centers) or is there something else I’m missing.
Also, assuming I rest the other three posts on top of the PT framing and use blocking & bolt them into the deck framing well, will this work.
I’ve been spending way too much time thinking about this, so any help would be greatly appreciated.
Matt
Edited 5/2/2007 3:29 pm ET by Mulch
  1. Mulch | May 02, 2007 10:30pm | #1
    bump
  2. Piffin | May 02, 2007 11:27pm | #2
    Yes, just beef up your framing under that post. By definition, a pergola does not handle a live load, only the dead load of its own material
    1. Mulch | May 03, 2007 06:16pm | #3
      Thanks Piffin, appreciate the feedback!
    2. DoRight | May 03, 2007 07:33pm | #4
      Yes, and then years from now someone will put a roof on that pergola and with global cooling it will get loaded with a record snow laod and . . .
      LOL.
      1. Piffin | May 03, 2007 08:35pm | #5
        H3ll, let's build it so they can lauch rockets off it then. You never know what some dork will try to do someday on the future!
