Pergola Rafter Question
nickspencer94 | Posted in General Discussion on September 27, 2020 11:33am
I’m working on my first big project. I have a 10×16 pergola. The long side includes three 6×6 posts 8 ft away from each other. There is another row of 3 posts 10 ft away perpendicular to those posts. All posts are set below the deck on concrete footers and deck posts. Posts are notched on top to recieve 2×8 beams. Currently have 2×6’s running the 10 ft length underneath the beams to give some stability. My wife was wanting to hang a rather large swinging day bed from the pergola on the side where the grill is next to the fence. I was wondering what size rafters I would need to support that kind of weight if it’s spanning 10 ft. I currently have 2×6’s bought for the rafters but from what I read I will need something bigger. I would prefer to avoid 2×8’s just so the top doesn’t get taller. Would 4×6’s work as rafters? Thanks for the help. Pictures are in the link below.
https://drive.google.com/folderview?id=1UIjpn2rtrZ9UC0TwmGg8-abCOfK_ESfI
    unclemike42 | Sep 27, 2020 08:08pm | #1
    https://www.homedepot.com/c/ah/how-to-hang-a-porch-swing/9ba683603be9fa5395fab9011729f559
    above might be worth a read.
    but it sounds like the day bed might be bigger, and attach at 4 points vs 2.
    one thing to consider is spreading the load over several rafters. Blocking between rafters could be used to transfer the load to a pair of rafters, and can even be extended to further transfer load to adjacent rafters.
    double 2x6 is stronger than a single 4x6.
    if a rafter table shows you could get 30 PSF live load from a ten foot span of 2x6 at 16 inch centers, live loads on a 4 ft section of the 10 ft span would be 30 times 40, or 1200 Pounds. (the forces are different, since span tables assume a floor deck to help spread the loads)
    Adding a swinging bed increases the need for braces to keep the columns vertical. This is especially true if there is any way the swinging bed could contact a column directly or indirectly.
    This is an informal discussion. If you want a solid answer, might want to contact an architectural engineer. They will get you an answer for the minimum structure for the application.
Installing Prefinished Cabinet Molding
Use these assembly techniques when installing crown risers and molding to minimize visible gaps and nail holes.
