persistent leak
Ray | Posted in General Discussion on January 1, 2009 07:11am
I have a tankless water heater, the brass fittings on the hot side have a bit of a problem.  I assume it’s due to the expansion and contraction of the fittings – it’s an outside-mounted water heater.  Can one of you pros recommend a pipe dope that will stop the leaks?  The installer put teflon tape on the joints and I’m getting nervous about tightening it any more – afraid I’ll break something.
Edited 1/1/2009 11:12 am ET by Ray
  1. Marson | Jan 01, 2009 07:21pm | #1
    I'm not a pro plumber, but the trick I've used is to use teflon paste with teflon tape OVER it. And dope the threads on the female side while you are at it.
  2. HootOwl | Jan 01, 2009 07:30pm | #2
    I would likely use Rectorseal pipe dope.  However, I would recommend using both the pipe dope and the teflon tape. Belt and suspenders.
    I apply my dope first and then place a couple/few wraps of the tape over that.  Never had a leak with this combination.  I have heard that some recommend the other way around, but I see no reason to change what has always worked without fail.
    1. Ray | Jan 01, 2009 08:35pm | #3
      Thanks guys, I'm off to the hardware store tomorrow.
Picture-Perfect Pergola
