Pex for hot water baseboard heat
garyGGHI | Posted in Construction Techniques on January 15, 2009 06:35am
Hello all, working on a new project house (freddie Mac). Baseboard hot water heat. Plumbing system was winterized in Feb of last year so as you might expect there are quite a few leaks. It is all in 3/4 copper now. What are the opinions of using oxygen barrier pex in place of the copper. I have been using quite a bit of pex in the past for potable water with good results.
Any favorite brands? I currently have the tools for 1/2 and 3/4 crimp fittings so would prefer to stay with those if all else is equal.
Thanks, Gary
  1. DanH | Jan 15, 2009 06:42pm | #1
    Funny how they use the term "winterized" to mean "turned the heat off and let everything freeze".
    God is REAL, unless explicitly declared INTEGER
  2. plumbbill | Jan 15, 2009 06:49pm | #2
    Pex was used for hydronic heat applications long before domestic plumbing, so no worries there.
    I use Uponor brand pex AKA Wirsbo, but since you already have the tools for the other I see no need to switch.
