Pex install question
andyb | Posted in Construction Techniques on March 19, 2007 03:25am
Using zurn pex for water supply in new construction, upstate NY.
Do you need to use a bushing on wall and plate holes?  Using a manifold system, 1/2″ homeruns from the basement to 2nd floor.  Sounds like the tubing expands and contracts quite a bit, didn’t know if rubbing at studs will hurt anything.
Love the stuff so far.   Thanks.  Andy
    shelternerd | Mar 19, 2007 03:27pm | #1
    You don't need bushings in holes drilled through wood.
  2. BoJangles | Mar 19, 2007 03:59pm | #2
    Drill a hole about twice the size of the tubing.
  3. Brian | Mar 20, 2007 03:45pm | #3
    Ditto what the others said - our inspectors make us foam any holes between floors, so that should create a "bushing" in effect.  Use the copper stub outs for terminations...love that pex!
    Treat every person you meet like you will know them the rest of your life - you just might!
    1. andyb | Mar 20, 2007 05:19pm | #4
      Just using "great stuff" foam?  I thought that might do a good job.
      1. Brian | Mar 20, 2007 06:56pm | #5
        Thats all the inspector requires, great stuff.
