PEX piping for landscaping sprinklers??
Keene | Posted in Construction Techniques on May 27, 2006 09:54am
I’m planning to put in a new landscaping sprinkler system in my yard.  I just read the article on PEX piping, and I’ve installed a lot of pex in home remodeling.  I’m wondering if anyone has ever used it for outdoor sprinklers.  I’ve got clean soil, and good pressure.  I live in Oregon and the freeze depth only drops about 6 inches deep,  I would be installing at 1 foot or lower.  I would  also install auto drains in any obvious low spots.  It may cost more than PVC but it seems a really quick way to do it.
Does anyone have any experience with this or any reasons why it wouldn’t work?
  1. hasbeen | May 27, 2006 10:12pm | #1
    bump
    "Doubt is not a pleasant condition, but certainty is absurd." Voltaire
    zak | May 27, 2006 11:03pm | #2
    I noticed the article said something about PEX not being suitable for direct burial in acidic soils- would that be a concern there?
    zak
    "so it goes"
    BillHartmann | May 27, 2006 11:59pm | #3
    How would you make the connections? Cost of fittings might be a problem.
    PVC is not the only way to do sprinkers.
    PE (polyethalene) is also used. Has barbed fittings. And it can be installed with a vibrating plow.
      tfarwell | May 28, 2006 05:56am | #4
      PEX is way too expensive for sprinkerlers. Use PE irrigation grade pipe with the appropriate fittings - it works well and is easy to install. Lowes, HD, Ace all have it in the sprinker section.
      Also, I live in the Portland area as well (Sherwood).
  • Smarter Stop Block
  • Square Walls Solo
  • Deck-Board Pry Bar
