Piano hinge question
curley | Posted in General Discussion on September 15, 2007 08:55am
I’m building a window seat based on an article in FHB #158. My problem has always been with the small brass screws that come with a piano hinge or something else that reqquires screwing a small brass screw into something like oak.
Is there some trick to screw those small screws in without ruining the finish/look of the brass screw.
Or are carpenters using their own screws rather than use the screws that come with the packaging
it seem like a TORX screw would be alot better
    IMERC | Sep 15, 2007 09:04pm | #1
    predrill with a Vix bit or the like....
    definitely bring yur own screws...
    WOW!!! What a Ride!
    1. Adrian | Sep 15, 2007 09:36pm | #2
      Or, predrill, then run a steel screw in, remove it, install the brass screw. Slow, but a lot faster than dealing with a bunch of stripped brass screw heads or a screw with the head torqued off.
       Cabinetmaker/college woodworking instructor. Cape Breton, Nova Scotia.
      1. mike_maines | Sep 15, 2007 09:53pm | #3
        Bingo
      2. curley | Sep 15, 2007 10:34pm | #4
        Thanks................
  2. Jamie_Buxton | Sep 16, 2007 01:56am | #5
    The problem with those little screws is that the cone of screw head hits the wood before the rest of the head hits the metal.   You have to screw it very hard to get the head to hit the metal, and often it strips or breaks.  The solution is to drill your pilot holes, and then hit each one with a countersink.   You can either move the hinge out of the way, or countersink the wood with the hinge in place.
    1. DanH | Sep 16, 2007 03:17am | #7
      Also, make sure you have the right size Phillips bit. The small screws don't leave a lot of room for error in bit size.
        JeffBuck | Sep 16, 2007 03:26am | #8
        bingo!
        always amazed at other carps that think all screws are #2.
        Jeff    Buck Construction
         Artistry In Carpentry
             Pittsburgh Pa
          Sphere | Sep 16, 2007 03:29am | #9
          They're not?  (G)Spheramid Enterprises Architectural Woodworks
          "If you want something you've never had, do something you've never done"
          SamT | Sep 16, 2007 04:48am | #11
          Awww, everbuddy knows that Piffen screws are #1SamT
            JeffBuck | Sep 16, 2007 06:19am | #13
            my number one favorite screws are actually #1 Pif's.
            use them lot's for double top secret cab installs.
            pretty sure from Rocklers.
            have 1/2" ... 5/8th" ... 3/4" and 1".
            look just like little tiny Pif screws ...
            but ya can't snap them little heads off.
            the smaller ones are #1 square drive.
            best part is the Pif screw designed threads ...
            little bugger bite into hardwood trim great.
            use them alot for "double back screwing" prefinished crown to the cab when I have open space above ... no exposed fasteners ... variable adjustment.
                 Pittsburgh Pa
            SamT | Sep 16, 2007 09:42am | #14
            http://www.rockler.com/product.cfm?page=2205 ???SamT
          3. DanH | Sep 16, 2007 03:31pm | #15
            And the advantage of those is that they're a lot easier to hammer in than regular wood screws (which don't seem too well designed for hammering at all).
    Sphere | Sep 16, 2007 03:04am | #6
    Also a little rub of candle wax helps with the screw going in, if you didn't run a steel screw in first, and are just following a VIX bit ( which I ALWAYS use for hinges).
  4. Snort | Sep 16, 2007 03:59am | #10
    It's a good excuse to get an impact driver...and Dri-Coat the screws. wax can cause some tough finishing problems.
    Someone's got it in for me, they're planting stories in the press
    Whoever it is I wish they'd cut it out but when they will I can only guess.
    They say I shot a man named Gray and took his wife to Italy,
    She inherited a million bucks and when she died it came to me.
    I can't help it if I'm lucky.
  5. BUIC | Sep 16, 2007 05:58am | #12
    I use my own, usually #4 x 1/2" that take a #0 square drive tip, like these...buic
    http://www.mcfeelys.com/cut-thread-square
Old House Air-Sealing Basics
