pipe railing
wvjack | Posted in General Discussion on May 18, 2005 11:37am
we have finished framing our home in WV.  Iam now putting up the wrap around porch.  The perimiter of the home is 70×32.  I am half way around building the deck of the porch(8′ deep 2×10 joists sitting on 6×6 posts 8feet apart.
I have a question on railings. I wnt to have pipe railings. Pricing the pipe was a rude awakening.  But then I saw 1/2″ rigid electrical conduit.  Does this sound reasonable to use this?
jack
  1. FastEddie1 | May 18, 2005 11:47pm | #1
    1/2" is a little small, 3/4 would be better.
    Is it really rigid conduit, or EMT?  The emt would be too light. for the top rail but would work for the balusters.
    1. wvjack | May 18, 2005 11:51pm | #2
      It is emt conduit.  But I would be using 30" lengths seting in a 2x6 top and bottom rail.
      1. ponytl | May 19, 2005 06:07am | #3
        1/2 bar stock is not that high... think i'm pay'n 4.50 per 20ft
        pony
      2. FastEddie1 | May 19, 2005 06:18am | #4
        Maybe I misunderstood the first post.  You will have 2x6 top and bottom rails and the emt will be the balusters or pickets in between.  That works.  You might want to clean off the printed labeling.  Drill a small hole in the bottom rail so moisture can drip out.  And be sure to maintain a legal spacing.
    G80104 | May 19, 2005 06:34am | #5
    Don't know how standard conduit will hold up to weather? GRC (galvanized ridgid conduit) or aluminum emt would hold up better. This will also cost more then standard conduit.
      Never seen it used for railing, so if you use it, post a photo of the finished product.
    1. DaveRicheson | May 19, 2005 12:50pm | #6
      I was wondering about the same thing. Standard EMT will last a few years outside in some protected areas before it starts to rust. If painted it can go many, many years.
      If he is using pt lumber for the top and bottom rail, all bets are off. I don't think the small amount of galvanizing on EMT would meet the requirements for ACQ treated lumber contact.
      Dave
      1. FastEddie1 | May 19, 2005 03:24pm | #7
        Put plastic caps on the ends of the emt to isolate it from the acq.I'm sorry, I thought you wanted it done the right way.
