Pipes bursting
billr | Posted in Energy, Heating & Insulation on January 26, 2003 02:49am
Hay All! During our current freeze here in Charlotte, NC ( I manage an apt. complex)
sever copper supply lines in unheated attached shed storage burst.  The piping supplies washers. There is a mixture of piping materials in the sheds some all copper, somes pex, and others a combination of both . To date the pex and/pex /copper hasn’t burst (I hope). Question: of the possible piping I could use which would be tolerant of a freeze? Also, is there any way to replunb with some sort of expansion. fitting?
  1. Piffin | Jan 26, 2003 03:08am | #1
    The pex is it!
    fittings might burst but the pex will stand a freeze
  2. JJ | Feb 03, 2003 11:02pm | #2
    insulating your pipes will help also
    1. Stray | Feb 04, 2003 10:43pm | #3
      I live north of you (NY) where we've been frozen since November.  I have a property where he well house is heated with a light bulb.  The bulb is on a thermostatic switch.  When the temp gets down to 40 or so, the bulb turns on.  The housing is well insulted, and it keeps a 4'X4'X6' enclosure heated even when it's -10 out.
      If the pipes are contained in a small area, it might be cheaper to buy a couple sheets of foam board, a can of "great stuff" expanding foam, and a lightbulb/thermostat set up.
      If you're freeze ups are really infrequent, invest in some heat tape (also comes with thermostat).
