I would like to place a 2′ wide x 4′ long 500 lb. granite bridge over the curve in this water feature stream.
been trying to figure out the best way to do it, but keep coming up empty.
any suggestions?
bobl Volo, non valeo
any suggestions?
Listeners write in about condensing dryers, giant gears, and saggy doors and ask questions about chimney safety, black windows, and rot-resistant assemblies.
Sono tube footings disguised as stones.
You get out of life what you put into it......minus taxes.
Marv
clarification
getting the piece of granite in place over the stream, which is manmade (EPDM)
Pipe works well for rolling heavy objects, preferably on something firm enough to support the pipe.
The easier way uses hydraulics of some sort. I like my guy, but not everybody has one:PAHS Designer/Builder- Bury it!
Back hoe with a sling. Or get whoever delivers the stone to put it in place with whatever he's using to get it off his truck.
Engine hoist. Clear 2x8s on the flat will hold 300# with a 5' span. 1/2"ply will support it across the lawn.
Samt
