Architects get away with murder….
Have the attached detail…..for some edgelit glass, between cased columns…..
I guess it’s what you might call a “concept” drawing, and someone else is supposed to actually engineer it.
How would all you bright folks do it?
(maybe some good Samaritan will post the sketchup file in the body of the message for me…I still haven’t got that trick figured out….)
Dehumidification is listed as a selling point for HPWHs, but are they actually effective at lowering humidity?
I used to be able to embed pictures, but now the system won't let me go back to revise my message, and put them in.
Anyway, here's your skp file as a jpg, so everyone can see it. (to do this, go to file>export>2d image)
My image is the way I'd put glass in columns, if I understand you right- are these windows?
Or maybe you just need a strip of glass, lit from inside the column. I guess I'd just glue that up as a sandwich. I'm not entirely sure what I'd glue it with, though- silicone? epoxy? I think epoxy would yellow. You'd want something really clear, so you couldn't see it through the glass.
zak
"so it goes"
What's the distance between columns?
Is the column width prescribed?
What lamps? Rope, incandescent, flouresents? Size?
Interesting. Well, it looks to me that the sub-structure would more or less hold the trim-work pressed against the glass, but I'd use a very clear silicon to hold the glass in place.
All the best...
To those who know - this may be obvious. To those who don't - I hope I've helped.
couple of things . . .
1) someone needs to access the bulb and 2) i wonder how much light will actually get through the edge of the glass. i would think the whole box needs to be self-supporting so the trim panels could be removed. And maybe add some semi-opaque acrylic/polycarb along the edges to allow more light to show through (kind of a milky-white glow).
scanned a drawing detail (apologize for the size/quality)
Edited 9/15/2006 11:41 am ET by draftguy
Looks good to me....
wow . . . you actually made that look like i knew what i was talking about (thanks) <g>
