Plans for double winder stairs
sillycat | Posted in Construction Techniques on June 4, 2022 07:34pm
I drew up some plans for a double winder stairs… measuring carefully height from floor to upper floor, number of steps, etc. but I’m getting old and afraid to start the project without some advice.  I have tried to find some “step by step” (excuse the pun) instructions but can’t find any for this type of stairs.  Obviously I would have to  start with basically a short wall type frame for the first landing but in order to put the stringers up I would need to have the second landing made so I could join them.  I’m not as sharp as I once was for figuring these things out.  If I could just see some pictures I think I’d have the confidence to try it.  I would like to use the space under the upper landing as a closet on the main floor.  Any suggestions or help welcome!  Thanks in advance.
See attached picture of the double winder stairs.
  1. hridyard | Jun 05, 2022 05:13pm | #1
    Try Andy Engel's book, "Building Stairs." He reviews all the stair variations in step by step simple instructions and photos. Using his book's guidance I recently built my (first and only) routed stringer custom stairway, and I am 50 years north of my last geometry class. Mr Engel just recently passed away, sadly, but is remembered fondly by many in this forum.
    Best tip- use a carpenter's calculator app on your phone to help with stringer layout to avoid cumulative error (1/32" off when multiplied over 16 treads is half an inch! )
    1. sillycat | Jun 06, 2022 09:14am | #2
      Okay, thanks. I've hesitated to buy some of the books on stair building because they may not include the variation that I'm looking for... a double winder. I already know how to build regular stairs, but I'm 77 now and sometimes my brain gets foggy and don't want to waste wood at today's prices!! :-(
      It looks like there are two different covers for Andy Engel's "Building Stairs" book. Do you know if the content is the same??
    2. BrianMac | Jun 07, 2022 10:10am | #3
      I managed to overthink the last set of winders I did and in hindsight should have just gone with the stacked boxes approach.
      This article is great:
      https://www.finehomebuilding.com/membership/pdf/11981/021067044.pdf
      To simplify your double, I would think of this as two different sets of winders, with two walls/platforms. A wall/platform for steps 4/5/6, then a taller wall/platform for 8/9/10, or 7/8/9/10.
