plaster goof
Henley | Posted in General Discussion on December 29, 2008 04:35am
I’m doing a two coat veneer ceiling.
Well I ran short of the base coat.
So my question is….
If I finish the rest of the first coat tomorrow morning,
can I apply the finish in the afternoon?
Or will I get discoloration from the two different batches?
    McDesign | Dec 29, 2008 05:14am | #1
    I think you'll get a mis-match at the join, but it MIGHT fade with time.
    1. Henley | Dec 29, 2008 05:17am | #2
      What if I finish the first coat, and then let both
      cure completely before top coating? Short of that I think it's time for paint.
        McDesign | Dec 29, 2008 05:28am | #3
        DW and I have only done the one-coat version, then let it dry for a month before painting - probably longer than we needed to.
        1. Henley | Dec 29, 2008 05:37am | #4
          Yeah, should have stuck with one coat.
          Always trying to make everything perfect you know... I had this nasty looking butt joint, so "Hay
          I know, I'll make it hard on myself!" For the record the basecoat is very gritty and
          harder to work with. I'd very much like to get a consistent color and not paint.
  2. MikeSmith | Dec 29, 2008 06:36am | #5
    you can break off the first coat anyplace, anytime
    final coat you want to break off where it won't show....like an inside corner or an outside corner
    but if  you get  caught out , you can break off  final coat too
     Diamond breaks off  better than  Imperial...  sometimes you can use joint compound  to blend a breakoff joint
    1. Henley | Dec 29, 2008 06:48am | #6
      Thanks Mike. Any thoughts about the time I should wait before
      second coat? Makes sense to me that I'd have to let the whole thing
      dry completely to avoid the seam bleeding through. But if I dampened the older part...
      1. MikeSmith | Dec 29, 2008 06:52am | #7
        are you going to leave it unfinished, or  paint it ?
        unfinished, the breakoff will show
        painted, it will not showMike Hussein Smith Rhode Island : Design / Build / Repair / Restore
        1. Henley | Dec 29, 2008 07:04am | #8
          Yeah, I wanted to leave it unpainted. So, no hope of letting it completely dry,
          then finish coating?
          1. MikeSmith | Dec 29, 2008 07:06am | #9
            yes.... you just have to do the  finish coat with  no break offMike Hussein Smith Rhode Island : Design / Build / Repair / Restore
          2. Henley | Dec 29, 2008 07:10am | #10
            That's what I was wanted to hear! LOL Thanks again.
            Chuck
          3. MikeSmith | Dec 29, 2008 07:19am | #11
            the finish coat is going to dry ( cure )  at different rates in different locations
            when i  watch the plasterers  they work across the area, applying it.... then they go back anf finish trowel it... then they go back with water  and flick it on with a brush and   polish it with their  finish trowels
            small walls, one  man...
            bigger walls, more men....
             but they keep working the wall until it's done... no stops
            Diamond has more working time than  Imperial
            if it kicks  , you're done.... the only thing you can do then is apply joint compound
            find a small wall to practise your technique onMike Hussein Smith Rhode Island : Design / Build / Repair / Restore
          4. Henley | Dec 29, 2008 07:34am | #12
            It's just bath, 11x12 ceiling. I've had a trowel in my hand since I was
            very young. So I feel comfortable tackling
            the laying off. Granted this is my first
            plaster project! Yeah, your method was what I was thinking. Covering the surface as rapidly as I
            can neatly manage.
            Then immediately going over it again.
            Adding water as necessary. One detail I read has me wondering. One
            of the many web pages I've been scouring talked
            about not over troweling it.
            Just didn't make much sense to me. I mean once
            it kicks it's done.
          5. Frankie | Dec 29, 2008 08:33am | #13
            USG has advised us to do the base and top coats the same day. When skimming with plaster, base coat must not be dry before applying topcoat. Wet is applied to wet for proper bond. That's one of the benefits of plaster - start to finish in the same day and no sanding.Joint compound is different. Each coat must be dry prior to the application of the next coat. Wet is applied to dry to get the suction for proper bond.When you are going to paint is the best time to practice your plaster work. The learning curve and any associated errors can be repaired with compound and then painted. Plaster cannot be sanded.Prior to top-coating yesterday's base coat, mist the base coat with water. As for overworking, one of the things to watch out for is "burning" the veneer. This is when the trowel is pressed too hard - during polishing - and causes a streak (dark patch/ stroke) to form. If you are doing the work all yourself, you won't need to worry about variation of stroke. Everyone has their own signature/ stroke. For ceilings, I prefer to use a mist bottle (an old Windex bottle) or better yet a pump tank used for applying pesticide to garden plants. You can buy one at the Big Box stores for $20. Traditionally a 6" brush is used (dipping it in a bucket of water) but a novice might have difficulty applying it to a ceiling without drenching the whole room.I hope this helps.Frankie
            Flay your Suffolk bought-this-morning sole with organic hand-cracked pepper and blasted salt.
            Thrill each side for four minutes at torchmark haut. Interrogate a lemon.
            Embarrass any tough roots from the samphire. Then bamboozle till it's al dente with that certain je ne sais quoi.
            Arabella Weir as Minty Marchmont - Posh Nosh
          6. Henley | Dec 29, 2008 08:53am | #14
            Yes, very helpful. Thanks.
            I had intended to do both coats today,but underestimated
            my material. I'm working on my own house, so it's a good opportunity to
            experiment. If it needs paint in the end, it's not a problem.
          7. yojimbo2 | Jan 04, 2009 06:50am | #16
            "That's one of the benefits of plaster - start to finish in the same day and no sanding."Yet drywall mud rules in construction. Is plaster a faster, better, less costly alternative? I would love to know more.I came across this plaster application on Youtube:http://www.youtube.com/watch?v=Wvf2UGMnjuEvery coolHere is the same product being applied over Durock for a tub surround:http://www.youtube.com/watch?v=VRrHJpUtQSwI wonder what they do for the corner, so they don't leak. The product becomes hydrophobic once it dries.A no tile shower, who awesome would that be?Anybody know if there is a locally available product like Tadelakt.
            Edited 1/3/2009 11:22 pm ET by yojimbo2
          8. Frankie | Jan 04, 2009 07:17am | #17
            Plaster work requires better and more skills - in application technique, time management and focus, to name a few. More skill requires more $$.Compound requires skill, but not as much and mistakes can easily be sanded out.As for dust - Clients don't care how much dust we are exposed to, especially if the dustier method is cheaper. Also, clients don't do the "dust calculation" of what they'll be exposed to when they sign the contract.Frankie
          9. yojimbo2 | Jan 04, 2009 07:31am | #18
            Has anyone done a Tadelak shower?I want to do one.
          10. MikeSmith | Jan 05, 2009 05:40pm | #19
            bump  for the TadelakMike Hussein Smith Rhode Island : Design / Build / Repair / Restore
          11. Henley | Jan 06, 2009 02:40am | #20
            In my recent web research I found this forum- http://www.muralsplus.com/cgi-bin/discus/discus.cgi?pg=topics Couldn't imagine a more well informed group then them.
          12. yojimbo2 | Jan 06, 2009 06:19am | #21
            thks for the lead.
          13. Henley | Jan 04, 2009 02:29am | #15
            Just wanted to say thanks for the help.
            I ended up with two top coats ( first one was full of mistakes). But the final look is indeed even, with no sign of the break in the brown coat. Things I've learned- Don't sweat the small stuff, just keep truckin.
            The cage mixer recommended by the manufacturer
            is impossible to clean.
            Consistency of the mix is VITAL! I'll post pictures if I ever get done Thanks again
            Chuck
A New Approach to Foundations
