We have an investment property that has tudor boards and a thick cement stucco(rough) as the siding. It has been below 20 degrees this week and the tenants have complained of the walls sweating. In the past, we do remember having some issues with moisture in this building.There is no insulation is this building. We are now wondering if we should rip this plaster out and insulate the cavity??Just not sure if it should be paper faced or not. I have read some stuff on the Dow Corning building science web-site and it has confused me somewhat. Any ideas out there. We reside in Northern NJ.Thanks so much.
Drill holes outside, and blow it in............patch and increase the rent $5 a month (not really!)
Hi Workman, Excess moisture is the cause of the condensation on the walls. Using the bath vent during showers and the exhaust fan on the range when in use should remedy the problem providing they are vented to the exterior of the house. Also make sure the dryer is vented to the exterior. This would be an immediate fix and should cost you nothing. Hope this helps. Carpster
no kidding!!---------they are only having this problem in the front of the building(2 walls) and these rooms are not far from a bath in which there is a fan but who knows if they run it??--------------thanks----------------i did find the site that i saw years back last nt that explains vapor barrriers and vapor retarders etc and after that i feel that this plaster is keeping the moisture from entering the inside(oil paint on these walls as well) so i would think that if i did rip these walls and insulate with unfaced batts(then paint drywall with latex), it may help the walls dry to the inside------------------------------but not posotive on this so will keep and eye out for the next month---------------------thanks again!!
" if i did rip these walls and insulate with unfaced batts(then paint drywall with latex), it may help the walls dry to the inside"
Nope. To the contrary, it would help wet the insulation, destroy its R value and promote rot and mold since any water vapor reaching the insulation would condense inside the wall instead on the surface of the wall. This "fix" would simply make things worse.
As mentioned in prior posts, the best solution here, IMHO, is to blow in celulose and keep the inside painted with a vapor barrier paint. Oh, and stress that exhaust fans are there for a purpose. Maybe even put a timer switch on it, or tie it in to the light circuit so it comes on whenever the light is on.
Mike HennessyPittsburgh, PA
boy does this stuff confuses me at times--------------i appreciate the help---------------------------i will have to hunt down someone for this job though---------------------can this insulation be blown in from inside though???---------------this stucco on outside is real hard and wired so i am thinking it will look like #### with holes everywhere??
It can be blown from in or out -- whichever is easier to patch. My installer can blow through holes small enough to fit between bricks, which means 1/2" or thereabouts, so patching doesn't have to be a huge deal. Lotta holes tho' -- two each bay on each floor.
They make switches for bath fans that start and stop automatically by sensing the humidity in the room. Under $40 IIRC.
Good to do whether you insulate or not...buic
You can wire the fan to go on with the light. You can also put both of them on a timer so it will turn off after a while.
You are on the wrong track to think of ripping plaster out. Batt insulation is the worst there is, and you can have better insulation blown in.
you could have the bathroom fan wired to a humistat so it runs automatically when RH is too high.
It's the difference in temp that's causing the sweating. Yes, you should insulate. Forget about ripping all the plaster down & doing fiberglass.. Find a reputable insulator & have blown in.
where in N. Jersey?
