Anyone familiar with plaster washers?
Read about them in This Old House.
Used for tightening sagging plaster ceilings and then you’re supposed to finish over them.
Any help would be great.
Thanks…
~Mike~
The code requires installing an approved material to slow the spread of fire between floors and adjacent vertical and horizontal cavities — here are the allowed materials and required locations.
Use 'em all the time/ Lee Valley has them by the hundred bag. Use sheetrock screws or roof nails. I like the screw.
Thanks I'll look on Lee Valleys web site.
If I'm not mistaken this is basically a fender washer with a dimpled center to allow the fastener to recess a bit?
Half of the harm that is done in this world is due to people who want to feel important. They don't mean to do harm but the harm does not interest them. --T.S. Eliot
the ones I used were much thinner than a washer. It also had holes to grab the next coat of plaster and some teeth to grab the existing plaster.
http://jhausch.blogspot.comAdventures in Home BuildingAn online journal covering the preparation and construction of our new home.
As JH said, they're very thin and have holes in them for the plaster or spackle to penetrate and have a dimpled hole for the fastener. They are about 1" in diameter.
http://www.leevalley.com/hardware/Search.aspx?c=2&action=n
I can see they'd also be good for fastening foam insulation in place, if you have something thick enough to screw to.
McFeeley's has them if you can't find them locally...
I think Charles Street Hardware in Boston sells them too.
